Not able to setup TPlink axe5400 router
  • June 6, 2024
  • 92 keer bekeken
I am trying to setup TP Link AXE 5400 tri band wifi 6E router on KPN network but it not able to connect. I tried using PPPoE setting but still unsuccessful. Can someone help please ?
2 reacties
Hello @Vikas, you could try to ask your question in the following topic:
  • June 10, 2024
Do you have television from KPN or only Internet.
If you only have Internet you can easily replace the Experia/KPN Box with your TP-Link but be aware that you need to setup the pppoe connection on vlan 6.
