Printer not connecting
  • December 16, 2021
  • 55 keer bekeken
Do not include personal information such as your address or phone number. What you write here is visible to everyone after placement.
Nico_
Topper
  • December 17, 2021
Hi @Sidhu and welcome to our forum!
What can i do for you?
  • December 17, 2021
Hello Nico
Thanks for the message, its a weird that my printer is not connecting. This started when I switched to KPN.
There are 2 options displayed on the printer( HP Deskjet 3050A)
  1. Push Button
  2. PIN
Push Button: On router press and hold the WPS button for 3 seconds to connect to the network
PIN, Enter the 8 digit pin in router configuration page and then press OK
I tried Push button - not sucessfull
for Pin method, I believe, this can be done in mijnmodem.kpn to see if the pin can be entered, unfortunately my admin password is not being accepted.
In both cases am unable to connect my printer and its creating lot of problems .
Could you help me out.
Regards
Sidhu
Nico_
Topper
  • December 20, 2021
To be honest i am not familiar with this model. Is there an option that you can connect this printer using the WPA code?
