Settings for DSL connection for Zyxel VMG4005-B60A
  • November 9, 2024
  • 270 keer bekeken
Hi
I would like to replace KPN box to zyxel modem, maybe someone have working settings for Zyxel and can share it
Current working settings  for KPN box:
encapsulation G993.2_Annex_K_PTM
MTU 1500
PPP username:  CC-00-F1-F6-97-30@internet
PPP pwd: ppp
I used settings Like below, turned OFF firewall, Zyxel established DSL connection,  but can’t establish PPP.  Do you know what is wrong?
  • November 9, 2024
Hello @Y.R see:
and:
  • November 9, 2024
Do you have TV from KPN?
You should initiatie the pppoe session on vlan 6.
Do you really mean the Zyxel VMG4005-B60A or do you mean the Zyxel VMG4005-B50A?
If you mean the B50A you should use it as a full-bridge modem with a router behind it.
  • November 9, 2024
Hi
Yes its B50A, I have no KPN TV.
vlan 6 for internet or TV?
For Vlan setting I have 2 parameter:
802.1p   and 802.1q
If I select “6” for 802.1p   what parameter should be for 802.1q ?
  • November 9, 2024
802.1q should be 6.
802.1p can be 0 or 1.
