Uitleg over firewall instellingen Experiabox 10A
  • sep 19, 2021 9:40 p.m. UTC
  • 10 reacties
  • 3575 keer bekeken
Hallo Forum, in het instellingenmenu van mijn Experiabox v10A, onder Netwerk => Firewall => Firewall, staan 4 checkboxen: Proxy, Java, AxtiveX en Cookies. Moet ik deze aanvinken? Wanneer wel/niet? Ik heb (uiteraard) een KPN internet abonnement. Alvast dank.
Beste antwoord door Bart_2020
Hallo @Bernardus W. ,
Firewall features greyed out , dus niets te kiezen, altijd “high”.
WebFilter features, wel te kiezen, maar in de praktijk weinig zinvol. ( HTTP vs. HTTPS).  Zie het verhaal van @Nick83 .
Dat die vinkjes daar zitten is achterhaald door HTTPS.
Volgens de help file (Engels):
Firewall
The Experia Box v10A provides extensive firewall protection by restricting connection parameters to limit the risk of hacker attack, and defending against a wide array of common attacks. However, for applications that require unrestricted access to the Internet, you can configure a specific client/server as a demilitarized zone (DMZ).
Firewall features
High
Enable Firewall, IDS (IDS, DDoS, blocking WAN Ping) and WEB Filter
Medium
Enable Firewall and IDS (IDS, DDos and blocking WAN Ping), Disable WEB Filter
Low
Enable Firewall, Disable IDS (IDS, DDoS and blocking WAN Ping) and WEB Filter
Off
Disable Firewall, IDS (IDS, DDoS, blocking WAN Ping) and WEB Filter
WebFilter features
Experia Box v10A's WEB Filtering feature, in addition to providing keyword filtering for the main URL and Host fields, also provides four additional filtering features: Proxy, Java, ActiveX and Cookies.  By providing these diverse filtering capabilities, the user is protected in multiple ways.
Proxy Filter
This filtering is mainly for the HTTP proxy service, so the detected port is the common port (80, 3128, 8080, 8000) of the proxy server.
Java Filter
This filtering is mainly directed to the content of the web page, and detects whether the host on the LAN side is downloading a Java file with ".js", ".class", and ".jar" as the suffix.
ActiveX Filter
This filtering is mainly directed to the content of the web page, and detects whether the host on the LAN side is downloading an ActiveX file with ".ocx", ".cab" as a suffix.
Cookies Filter
This kind of filtering is mainly to find whether there is a "Cookie" field in the HTTP protocol header in the HTTP request (GET/POST/HEAD).
Groet Bart
10 reacties
Bart_
  • sep 20, 2021 6:39 p.m. UTC
Hallo @Bernardus W. De vraag is een beetje wat je er mee wilt bereiken. Als je zo uitgebreid mogelijk kunt omschrijven wat je precies wilt doen, kan onze community je ongetwijfeld snel een goed antwoord geven!
  • sep 20, 2021 8:10 p.m. UTC
Ik denk dat ik daar ook een probleem mee heb. Wil een Roomba stofzuiger via Wifi aanmelden en kunnen bedienen. Het lijkt goed te gaan totdat het allemaal vastloopt. De Roomba kan ik wel in het modem zelf terugzien maar de app ( Android|) zelf loopt verder cast omdat het verder aanmelden niet lukt. Veel geprobeerd. Maar kan verder niets vinden . Hoop dat als ik de juiste poort openzet het wel gaat lukken.
Hoop dat iemand het wel is gelukt en er mij mee kan helpen.
  • sep 21, 2021 8:20 a.m. UTC
Beste Bart,
Dank voor je reactie. Wat ik wil bereiken: ik wil mijn netwerk goed wil beveiligen, maar ik wil ook goed kunnen internetten. Mag ik de vraag omdraaien? Welk effect hebben de 4 checkboxen? Is het voor dagelijks gebruik (beetje surfen over het net, online shoppen) verstandig om deze alle 4 aan te vinken? Ik kan cookies ook in de browser blokkeren, wanneer kan ik het beter in de browser doen, wanneer in de router? :-)
Groet, B.
Bart_
  • sep 23, 2021 7:37 a.m. UTC
Dag @Bernardus W. Als het je gaat om veilig internetten dan zou ik je aanraden om KPN Veilig te installeren en te gebruiken. Daarmee zit je goed en hoef je niet met allerlei instellingen in je Experia Box in de weer te gaan.
  • sep 23, 2021 10:06 a.m. UTC
Hoi Bart, dank je wel voor je reactie. Niet om flauw te doen, maar ik zou graag een inhoudelijk antwoord willen. Doen deze vinkjes iets? Is het beter om ze NIET aan te zetten? Maar waarom zitten die checkboxen daar dan? Alvast dank, groet B
  • sep 23, 2021 11:20 a.m. UTC
Het is de eerste keer dat ik over deze opties lees. En ik vraag me ook af wat deze opties betekenen.
Cookies is al helemaal vreemd. De meeste sites zijn https tegenwoordig. Dat houd is dat het verkeer, dus inclusief cookies, versleuteld is. De router kan daar niets mee doen. Die kan het alleen maar doorgeven. Die kan geen cookies blokkeren ofzo. Echt niet.
Bart_2020
  • sep 23, 2021 12:15 p.m. UTC
Firewall
Firewall features
High
Medium
Low
Off
WebFilter features
Proxy Filter
Java Filter
ActiveX Filter
Cookies Filter
Groet Bart
  • sep 23, 2021 12:29 p.m. UTC
Wow @Bart_2020, dank voor je reactie. Hier kan ik wel wat mee. Voordat ik nog meer vragen stel over de instellingen: heb je een linkje naar de (Engelse) helpfile? Die had ik nog niet gevonden.
Bart_2020
  • sep 23, 2021 12:55 p.m. UTC
In de web interface van de Experia Box  v10A zit een help button (dus geen linkje) naast de “Save settings” button. Sommige pagina’s hebben die button. De help informatie is niet altijd actueel. Veel schermen zijn gewijzigd, de help file niet.
Groet Bart
  • sep 23, 2021 1:11 p.m. UTC
Top, ik zie het. Dit was mij ontgaan. Dank.
