Wifi does not work with HP laptops
  • mrt 3, 2023 12:44 p.m. UTC
  • 1 reactie
  • 99 keer bekeken
I have 3 HP laptops at home and none stay connected to the wi-fi, when i troubleshoot on the laptop it says there is no default gateway available. Every other device works fine. Wi-fi signals are all green its just an issue with the laptops because it is connected but with no internet.
Beste antwoord door Anonymous
Hello @Dipo7
Do you have a Box 12 modem?
There are problems with certain networkcards like the Intel AX201, often solved by changing the Bandwidth to 80MHz.
See this page where to do that: https://www.kpn.com/service/actuele-wifiproblemen.htm
1 reactie
  • mrt 3, 2023 1:30 p.m. UTC
Hello @Dipo7
