Geen WiFi OnePlus [ENG]
  • May 4, 2020
  • 109 keer bekeken
My wifi getting disabled automatically in OnePlus 5t. I thought it is some software problem so I went to customer care they installed the new latest software but the problem is still there. What do I do?
*Admin: reactie afgesplitst, eigen topic aangemaakt.
Beste antwoord door Susan_
Hi @dayanbooker, thansk for you message!
I am curious about this problem. What settings do you have on WiFi networks? Is it possible that you have automatic switching between WiFi and mobile network turned on?  And, do you have this problem with any WiFi network or only with the WiFi network at home? If the WiFi network is from KPN, which Experia Box do you use? And, do you have this problem with any WiFi network or only with the WiFi network at home? Have you already tested whether it works if you forget the WiFi network and log in again with the password?
I would like to hear from you, so we can help you with this problem!
  • May 10, 2020
Yes I have check me check out this. Thanks doe.
  • May 10, 2020
I have a OnePlus 5T too and I don't experience any problems with it.
What do you mean by "getting disabled". Is it "turned off" or "getting disconnected"?
Susan_
  • May 10, 2020
Susan_
  • May 15, 2020
@dayanbooker we haven't heard from you in a while. Can we still help you with this or is your problem solved?
