KPN SIP Asterisk configuration pjsip
  • April 20, 2022
  • 1 reactie
  • 1391 keer bekeken
Hi All,
Last weekend I’ve been migrated from XS4ALL to KPN VOIP.
After almost 12 hours of struggles I managed to get Asterisk 18 configured.
Information is scarce and it was a lot of trial and error.
Here is my config:
pjsip.conf
[simpletrans]
type = transport
protocol = udp
bind = 0.0.0.0
[kpn-auth]
type = auth
auth_type = userpass
username = aabaXXXXXXXX@ims.imscore.net
password = XXXXXXXXXXXXXXXX
[kpn-reg]
type = registration
outbound_auth = kpn-auth
transport = simpletrans
server_uri = sip:ims.imscore.net
client_uri = sip:+31XXXXXXXXX@ims.imscore.net
contact_user = inbound-kpn
outbound_proxy = sip:voip1-ext.kpn.net\;lr
retry_interval = 60
[kpn-aor]
type = aor
contact = sip:ims.imscore.net
[kpn-out]
type = endpoint
context = default
disallow = all
allow = alaw
aors = kpn-aor
from_user = +31XXXXXXXXX
from_domain = ims.imscore.net
[kpn-id]
type = identify
endpoint = kpn-out
match = voip1-ext.kpn.net
Just define an extension inbound-kpn where all the incoming calls are sent.
To send calls to kpn define an extension as below:
exten => _9., 1, Dial(PJSIP/${EXTEN:1}@kpn-out,60)
 same => n, Hangup
All the dialled numbers starting with 9 are forwarded to kpn.
I hope it will save hours from your life.
1 reactie
  • May 9, 2022
Ja, dankjewel.
Hieronder vrijwel dezelfde pjsip.conf.  Dit zijn de verschillen:
  • Mijn Asterisk zit achter het modem dat NAT doet. Daarom definieer ik wat mijn vast IPv4-adres is  ( 82.NNN.NNN.NNN ) zoals Asterisk weet hoe de buitenwereld haar ziet.
  • Mijn interne netwerk is 192.168.0.0/24
  • Ik heb twee VoIP toestellen. Interne nummers zijn 1107 en 1109
  • Die 1107 en 1109 komen uit basic-pbx van Asterisk source. Daar komt ook de context DCS-Incoming vandaan.
  • Op 192.168.0.9 zit een test Asterisk, gesprekken van die SIP trunk landen ook in context DCS-Incoming.  Daarmee kan ik binnenkomen gesprekken testen zonder dat ik via de (dure) telefoniewolk ga.
;================================ TRANSPORTS ==
; Our primary transport definition for UDP communication behind NAT.
[transport-udp-nat]
type = transport
protocol = udp
bind = 0.0.0.0
; NAT settings
local_net = 192.168.0.0/24
external_media_address = 82.NNN.NNN.NNN
external_signaling_address = 82.NNN.NNN.NNN
;================================ CONFIG FOR SIP ITSP ==
; Registration for KPN VoIP
[kpn-auth]
type = auth
username = aabaNNNNNNN@ims.imscore.net
password = PA55W0RDPA55W0RD
[kpn-trunk]
type = registration
transport = transport-udp-nat
client_uri = sip:+31NNNNNNNNN@ims.imscore.net
retry_interval = 60
[kpn-aor]
type = aor
[kpn-out]
type = endpoint
context = DCS-Incoming
disallow = all
allow = alaw
aors = kpn-aor
from_user = +31NNNNNNNNN
[kpn-id]
type = identify
endpoint = kpn-out
;================================ ENDPOINT TEMPLATES ==
; Our primary endpoint template for internal desk phones.
[endpoint-internal-d70](!)
type = endpoint
context = Long-Distance
allow = !all,alaw
direct_media = no
trust_id_outbound = yes
device_state_busy_at = 1
dtmf_mode = rfc4733
[auth-userpass](!)
type = auth
[aor-single-reg](!)
type = aor
max_contacts = 1
;================================ ENDPOINT DEFINITIONS ==
; Below are the definitions for all staff devices, listed by department.
; Super Awesome Company uses the MAC address of their devices for the auth
; username and the extension number for the name of the endpoint, auth and
; aor objects. If your phones must use the same user ID and auth name then
; you will need to customize the endpoints accordingly.
;================================ MANAGEMENT ==
;Lindsey Freddie
;President for Life
[1107](endpoint-internal-d70)
auth = 1107
aors = 1107
callerid = Lindsey Freddie <1107>
[1107](auth-userpass)
username = 1107
[1107](aor-single-reg)
mailboxes = 1107@example
;Terry Jules
;Director of Sales
[1109](endpoint-internal-d70)
auth = 1109
aors = 1109
callerid = Lin Phone <1109>
[1109](auth-userpass)
username = 1109
[1109](aor-single-reg)
mailboxes = 1109@example
[my-itsp]
type = endpoint
aors = my-itsp
outbound_auth = my-itsp-auth
disallow = all
allow = alaw
[my-itsp]
type = aor
contact = sip:192.168.0.9
qualify_frequency = 15
[my-itsp-auth]
type = auth
username = my_username
; [my-itsp-reg]
type = registration
; outbound_auth = my-itsp-auth
; server_uri = sip:192.168.0.9
; client_uri = sip:my_username@192.168.0.9
[my-itsp-identify]
type = identify
endpoint = my-itsp
match = 192.168.0.9
P.S. dit is met Asterisk 16.16, dat is een LTS versie.
