Macbooks won't stay connected to Wifi
  • dec 18, 2024 10:32 a.m. UTC
  • 1 reactie
  • 78 keer bekeken
My Macbook and my daughter’s are constantly kicked off our KPN fiber Wifi. Our iPhones work fine with the Wifi as does my son’s PC. If I reset the modem it works for a while but the next day we’re back to getting kicked off every few seconds. Any ideas? Thank you. Also, my Macbook connects fine to my phone’s hot spot so I know it’s not a problem on the laptop.
Hello ​@J Hanchett, welcome.
Weird that your Macbook and your daughter's Macbook seem to lose internet connection all the time. I understand why you might say that it's not an issue with your laptop, as it works just fine when connecting to your phone's hotspot. However, I think it's complicated, because your phones and your son's PC seem to work just fine. Therefore, I'd like to advise you to follow the steps here: Last van internet- of wifi-problemen?. This should help you with the issues you're having.
1 reactie
Denise van KPN
  • dec 20, 2024 9:30 a.m. UTC
