Ambigous characters in admin password: cannot login wifi extender
  • October 9, 2023
  • 106 keer bekeken
Hello.  Recently I started having problems with Wi-Fi extender and
wanted to log into the modem admin site (for the first time), but
found it impossible to do because the admin password printed on the
back of the modem uses some kind of dash symbol.  This is my guess
though, I don't know if this is the reason, but I tried multiple
variants, and still no luck.  The dash looks about the right size for
the typographical minus sign (i.e. longer than hyphen that's typically
used for all kinds of dashes because it's immediately accessible from
most keyboard layouts).
As a consequence, it would be nice if:
a. You never used characters that aren't immediately available on
   European or US keyboard layouts.
b. Use monospace font for writing passwords because the amount of
   space surrounding some typographical characters is ambigous in
   the font you've chosen: it's possible to interpret it as having
   spaces around symbols.
To make this more concrete, these are the combinations I tried:
1F:d6s — Z;w
1F:d6s—Z;w
1F:d6s-Z;w
1F:d6s - Z;w
Ideally, it would be also great not to use similar symbols.  Colon and
semicolon create problems for people with impaired vision, especially in
the selected font.
All this said: is there any way to log into the admin panel if I
cannot guess my password?
Thank you!
Hi @wvxvw and welcome to our forum!
Understandable that sometimes these characters can be confusing. Some look especially alike. If you’ve got the Box 12 router (square and black) then there should be a QR code on the back of it as well.
Have you tried using that one to log in? Then it should use the right password immediately.
Sanne van KPN
  • October 13, 2023
  • October 13, 2023
Thanks.
It appears that I typed the password correctly, but logging in isn’t possible for some other reason.
Do you perhaps have any ideas why would that be?
Is there perhaps a telnet or an SSH server on the modem?
Sanne van KPN
Logging in should always be possible, unless the password has been adjusted.
If it's not working out, could you try resetting your router? I've put the link through Google Translate for you, so it's possible it isn't translated a 100%. However, I hope the instructions are clear and that they work.
If not, do let me know!
