Can I use KPN wifi enhancers when being subscribed to another provider?
  • feb 11, 2026 10:14 a.m. UTC
  • 1 reactie
  • 62 keer bekeken
Is it possible to adapt KPN enhancers to another internet provider after unsubscribe from KPN
Hi ​@Labzovskii. Welcome to our community, a very good question.
Although the SuperWifi units are designed for KPN modems you can also use them with another modem or network. However, you do need to switch off the wifi on your modem. Otherwise you’ll end up creating two separate networks. Another disadvantage is that they will no longer receive updates from our servers.
In summary: connect one SuperWifi unit to your modem using a cable. Unfortunately we can’t offer further support for this setup, but I hope you manage to get it working. 😊!
1 reactie
Forum|alt.badge.img+28
  • feb 12, 2026 4:22 p.m. UTC
Â
