KPN Superwifi 2: not able to login with admin password
  • October 17, 2024
  • 1 reactie
  • 171 keer bekeken
Gaurav19
Nieuwkomer
Hello,
I am trying to login in KPN superwifi 2.0 to change SSID so that it matches with modem (from new provider).
I tried resetting the device but still it is saying incorrect password when trying login with:
username: admin (which is ineditable)
password: admin password on the back of device.
How can I proceed? and is it possible to change SSID of the device to match with modem of new internet provider?
Hello @Gaurav19! If I understand correctly, you're using a different provider for internet and are trying to connect the SuperWifi to your modem. You should know that the SuperWifi only mesh with the KPN modem. So, changing the SuperWifi name and password might interfere with your providers modem. Therefore, I'd suggest to use a different name.
Regardless, you want to be able to login to the modem. Here you will find the instruction for logging in: KPN SuperWifi: van specificaties tot instellingen.
1 reactie
Denise van KPN
