SuperWifi 2 doesn't appear in the Wifi list after installation
  • apr 13, 2026 10:33 a.m. UTC
  • 42 keer bekeken
I followed the steps described on this thread several times
The Wifi boosters have green light but they do not appear in the Wifi list at all.
I have no idea what to do next. Any hints?
Hi ​@DanielT. Welcome to the KPN Community! Thanks for sharing this. At KPN it indeed works a bit differently compared to Ziggo. The WiFi boosters (SuperWifi/Experia Wifi) don’t create a separate network, instead they work together to form one large WiFi network with the same name (SSID). This is also known as a “mesh network.”
The advantage is that your devices automatically connect to the strongest signal in your home, without you having to switch networks manually. This usually results in a more stable and user friendly experience. If you would still prefer a separate WiFi network (for example for guests or smart devices), you can create a guest network in the modem settings.
2 reacties
  • apr 13, 2026 2:23 p.m. UTC
Solved: Ok, I am coming from Ziggo and there I had a system that created a separate wifi - this is not the case here, those are boosters and act together in the same network.
Vikash van KPN
  • apr 15, 2026 12:52 p.m. UTC
