SuperWifi points are not working, after removing the cable the light turns red
  • April 10, 2026
  • 158 keer bekeken
Hi All,
W ehave done multiple cycles of reset  Super Wifi device.
Also pess WPS button of modem and Supre wifi.
Still after we remove LAN Cable it becomes red. We dont know what to do now further or where to cotac to get this resolved
The fact that the light goes red when you remove the cable means that the Super Wifi is losing its connection with the modem. There can be a few causes for that. But to be able to look into that, I need more information about your devices.
  • Which SuperWifi do you have? The white or the black one?
  • Which modem do you have?
  • Has it worked before?
If you would also fill in your forum profile, I can check the technical details.
7 reacties
  • April 10, 2026
Ook ik heb dat probleem. Het is ontstaan nadat ik het wachtwoord voor de KPN Box 12b heb gewijzigd, moet dat ook bij de Super Wifi 2.0 gebeuren en hoe doe ik dat?
  • April 13, 2026
Hey ​@pradnya, welcome! That sounds like a frustrating experience. Let's see if we can get this fixed. For that, I have a couple questions:
Hey ​@aza, ik zag dat je hier een eigen, ouder, topic over hebt, maar dat het daarin niet tot een oplossing is gekomen. Ik zie dat mijn collega je een belafspraak had aangeraden. Was dat nog gelukt? Zo ja, wat is daar uitgekomen?
  • April 13, 2026
Ik heb nog geen contact opgenomen, zoek eerst zelf nog even verder.
Heel attent, dat u de gesprekken in de gaten houdt.
  • April 15, 2026
We have exchanged the super wifi point 2 times and still there is issue .
minimum 20 times we have done plug -unlpug , set reset of MODEM and Super Wifi separately.
This is not working at alll.
Support team asked me to BOOK PAID Appointment of 100 Euro for fixing the problem.
my question here is Why I should pay for the problem whcih KP is facing since 3 4 year sfor almost every customer.
On call, team give us instruction which can be given by CHAT GPT also and also from the page .
I need solution to the problem and not the steps of Configuration.
  • April 24, 2026
  • April 28, 2026
Super WiFi 2.0, black
KPN Box 12b
Yes
Ik snap dat je graag hulp wilt bij jouw situatie ​@aza, maar het kan toch zo zijn dat jouw situatie anders is dan die van ​@pradnya. Om te voorkomen dat twee cases door elkaar heen gaan lopen. vragen we jou om je weer te voegen in je eigen topic. Als je daar een nieuw bericht plaatst, dan komt de moderator vanzelf weer bij je terug.
Of je kunt een belafspraak inplannen. Dit doe je door op belafspraak te klikken en dan rechts onderin te kiezen voor ‘Maak een belafspraak’. Je hebt daar geen Facebook of X voor nodig. De chatbot Dot gaat je helpen met het maken van een afspraak.
