Why is Wifi off in the Experia Box? I have a good network still
  • August 24, 2023
  • 10 reacties
  • 146 keer bekeken
If I login to my Experia box, and browse the settings, I see under wifi that iy is out! Still enough coverage for the whole house , but why is it out? I have 2 of the wifi spots from kpn, and 1 is connected by an ethernet cable, so is that the reason?
Thanks in advance
Adam
10 reacties
Cappuccino2
Helper
Depends on the type of experia box modem you have in use.
  • August 24, 2023
Experia box v10a, I think
Cappuccino2
Helper
No need to guess as its written on the modem
Cappuccino2
Helper
The v10a should form mesh wifi with the kpn wifi  spots so wifi should stay on, you could enable it manually.
Hi @Engelse69, the Experia Box V10a should be able to mesh with our Wifi devices. Only the V10 (without the a) should turn of Wifi in the modem. Can you take a closer look to which modem you have?
  • August 31, 2023
I have the v10 experia box. Does it make a difference with wifi on or off?
Cappuccino2
Helper
The experia v10 does not support mesh wifi with kpn wifi spots, so wifi on the experia v10 should be disabled and at least one kpn wifi spot should be connected wired with the experia v10.
  • August 31, 2023
Ok. Thats the setup I have ( 2 wifi spots 1 hard wired) so I can leave the wifi off
Cappuccino2
Helper
Yes
  • August 31, 2023
Thank you
