Wifi booster does not give green light when I connect it wirelessly
  • October 23, 2024
  • 1 reactie
  • 85 keer bekeken
GDRDABARERA
Deelnemer
Hi KPN support,
i connected wifi boosters to the modem as per the instructions provided online. It is connecting via ethernet cable. But when i try to connect it wirelessly in my second floor , it gives red light even after 30 mins.
I tried reseting the booster twice and trying twice, but it does not work. I need some mechanic help- Looks like either booster is not working or wifi is not strong enough even to the stair case of the first floor from ground floor.
Hello @GDRDABARERA. For the correct installation of your SuperWifi, I'd advise you to check this topic: KPN SuperWifi: van specificaties tot instellingen.
If you want, you can request a mechanic to come check it out for you. For more information, see: Servicemonteur - Afspraak met KPN servicemonteur.
1 reactie
Denise van KPN
  • October 25, 2024
