Digitenne Signal lost
  • April 16, 2020
  • 161 keer bekeken
Hello All,
My Digitenne was working perfectly until all of a sudden the signal was lost. Tried to restart it etc but no chnage. 0% signal on all channels.
Has tried to change the orientation of the antenna also with out any success. Then I also tried a second antenna I had (brand new) but no change. 0% on all channels.
Called customer support and they said that they will send me another antenna. I do though doubt that the problem is the antenna as i have tried 2 different antennas (one was new) and there is zero signal
Please help
Receiver is ZXV7200
Beste antwoord door Noordzee
Hoi @thomascheimarios ,
Wil je het volgende eens proberen?:
1/ Zorg dat er bij de ontvanger of antenne geen externe storingsbronnen staan in de directe omgeving. Denk dan aan b.v .een modem, LED-lamp of DAB+-radio.
2/ Haal de ontvanger even vijf seconden volledig van de stroom af.
3/ Zet de antenne op een mooie hoge plek.
4/ Zet de ontvanger (en TV) weer aan.
5/ Ga in het menu terug naar de fabrieksinstellingen.
6/ Geef een nieuwe opdracht zenders zoeken, maar dan via de optie uitgebreid zenders zoeken.
7/ Draai de antenne eventueel een beetje bij aan de hand van signaalmeter uit het menu.
Would you like to try the following ?:
1 / Make sure that there are no external sources of interference near the receiver or antenna. Think, for example, of a modem, LED lamp or DAB + radio.
2 / Disconnect the receiver completely for five seconds.
3 / Place the antenna in a nice high spot.
4 / Switch the receiver (and TV) back on.
5 / Return to factory settings in the menu.
6 / Give a new search for channels, but then via the advanced search channels option.
7 / If necessary, adjust the antenna slightly using the signal meter in the menu.
  • April 16, 2020
Forum|alt.badge.img+28
Hi Thomas, welcome on our board.
Did you try the tips given by Noordzee?
Let us know.
@Alex_P , Thank for your replies.
Had already tried all of the above without  any success. That's why I posted on the forum.
Then a couple of hours later the signal was restored. I suppose there was something with the signal in the area.
  • April 22, 2020
Good that it works again! :thumbsup_tone3:
The restore of the signal could take some time.
I'm glad everything works well now. You know where to find me if necessary.
