Can you please tell me when will I receive my first invoice?
  • apr. 25, 2023 8:12 a.m. UTC
  • 114 keer bekeken
Hello,
Yesterday I received this message:
”Beste klant, vandaag start uw nieuwe factuurmaand. Uw actuele bundelstand is beschikbaar op de MijnKPN app. Groet, KPN”
but invoice nowhere to be found.
I don’t wanna get to debt or anything, every advice counts.
Thank you! 🙂
Beste antwoord door RBxx
The invoice normally appears in the MijnKPN app 3-4 days after the message you've received.
The amount due will be debited from your bankaccount one week later.
RBxx
  • apr. 25, 2023 8:25 a.m. UTC
RBxx
  • apr. 30, 2023 3:51 p.m. UTC
Hi @Lukinemi   Have you already received the invoice? It should be available in MijnKPN by now.
  • apr. 30, 2023 3:55 p.m. UTC
Hi @Lukinemi   Have you already received the invoice? It should have been sent by now.
Yes I did, but it was after almost one and half months which I understand now since it’s my first invoice and I started in the middle of the month but it’s the reason why it was concerning.
Thank you for your help. :)
RBxx
  • apr. 30, 2023 4:02 p.m. UTC
OK, that's clear. The first invoice often takes a bit longer.
I had the same experience when I started my subscription last year. From now on, you will receive an invoice once a month on the same day.
Glad I could help you.
