How can I get a copy of my previous invoices?
  • July 19, 2022
  • 110 keer bekeken
How can I get copy of bills older than the last four months?
Beste antwoord door RBxx
Hi @TuJu
On the main page of MijnKPN (website) you’ll find only the last 4 bills.
However, when you select “Producten” at the top of the page you’ll find all your products.
Select one and you’ll see the last 12 bills on the right. Click on “Bekijk alle facturen”.
If you use the MijnKPN app, you can download the last 20 invoices.
2 reacties
RBxx
  • July 19, 2022
Hi @TuJu
Hi @TuJu, welcome to our forum. I see Ruud has already helped you out. Did you find the invoice using this method?
