sinds een aantal weken heb ik een box 12 omdat de wifi verbiding van mijn oude xperiabox 10 instabiel was.
nu heb ik een nieuwe box 12 gekregen maar deze lijkt nog veel erger hierbij valt niet alleen de wifi maar de hele modem geregeld uit.
vandaag is het zelfs zo erg dat hij elk uur wegvalt
in het log zie ik het volgende voorbij komen
Â
15.11.2021 21:44:31 | Info | SYS | TR-069 connectivity to (hengelo0.cust.kpn.net) has been closed |
15.11.2021 21:44:31 | Info | SYS | TR-069 connectivity to (hengelo0.cust.kpn.net) has been initiated |
01.01.2013 01:00:36 | Info | SYS | TR-069 connectivity to (hengelo0.cust.kpn.net) has been closed |
01.01.2013 01:00:36 | Info | SYS | TR-069 connectivity to (hengelo0.cust.kpn.net) has been initiated |
01.01.2013 01:00:35 | Debug | DNS | DNS name resolution failure (216.58.202.4.in-addr.arpa) |
01.01.2013 01:00:35 | Debug | DNS | DNS name resolution failure (google.com.onion) |
01.01.2013 01:00:35 | Debug | DNS | DNS name resolution failure (*google.com) |
01.01.2013 01:00:32 | Info | PPPOE | PPPoE connection successfully established with user credentials. |
01.01.2013 01:00:29 | Info | DHCPC | The WAN DHCP client IP address 10.88.48.112 |
01.01.2013 01:00:26 | Info | DHCPC | WAN DHCP client (1) started |
01.01.2013 01:00:26 | Info | UPNP | UPnP functionality has been activated |
01.01.2013 01:00:24 | Info | WETH | WAN Ethernet connectivity has been established |
01.01.2013 01:00:24 | Info | LETH | An Ethernet port is now connected (2/1000/FULL) |
01.01.2013 01:00:24 | Info | LETH | An Ethernet port is now connected (1/1000/FULL) |
01.01.2013 01:00:18 | Debug | DNS | DNS name resolution is now active |
01.01.2013 01:00:18 | Info | DHCPS | The LAN DHCP Server is active |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been deactivated (.) (band : 5GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been deactivated (.) (band : 2.4GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been deactivated (KPN Fon) (band : 2.4GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been deactivated (KPNF8C3C6_guest) (band : 5GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been deactivated (KPNF8C3C6_guest) (band : 2.4GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been activated (Swart) (band : 5GHz). |
01.01.2013 01:00:18 | Info | WIFI | WLAN has been activated (Swart) (band : 2.4GHz). |
01.01.2013 01:00:17 | Info | WIFI | Channel: (0/64) Channel Hopping initiated/Manually initiated |
01.01.2013 01:00:17 | Info | WIFI | Channel: (0/6) Channel Hopping initiated/Manually initiated |
01.01.2013 01:00:15 | Info | SYS | The Modem has successfully powered up |
01.01.2013 01:00:28 | Info | UPNP | UPnP functionality has been activated |
01.01.2013 01:00:28 | Info | DHCPC | WAN DHCP client (1) started |
01.01.2013 01:00:27 | Info | WETH | WAN Ethernet connectivity has been established |
01.01.2013 01:00:27 | Info | LETH | An Ethernet port is now connected (2/1000/FULL) |
01.01.2013 01:00:27 | Info | LETH | An Ethernet port is now connected (1/1000/FULL) |
01.01.2013 01:00:14 | Info | SYS | The Modem has successfully powered up |
15.11.2021 21:40:07 | Debug | DNS | DNS name resolution failure (wpad.kpn) |
15.11.2021 21:35:22 | Debug | DNS | DNS name resolution failure (wpad.kpn) |
