Hi
I have taken Fibre optic connection and I am using my own router which has openwrt firmware.  I tried to change in the settings and I still see different DNS address. Can anyone please help me on this?
Thanks
Badri M
The DNS server assigned to your workstation will change after a renewal of the DHCP lease.
Thanks wjb.  Its going to be more than a day now.  What is the DHCP lease time?  Cant we have the option to force reset it?
Regards
Badri M
If you restart your workstation you will get a new DHCP lease.
I restarted my router many times but still getting the same DNS server.  What is it wrong?
Thanks
badri M
Can you post some screenshots of the settings on your router and the settings on your workstation.
Hi wjb
Thanks for your immediate support.  I verified in openwrt forum and it looks like its my mistake.  I wrongly configured DNS address.  I followed below thread in openwrt and it started working.
https://forum.openwrt.org/t/correct-way-to-set-dns-server/34019/24
Thanks
badri m
