Fiberglass Light off since the installation
  • October 4, 2024
  • 72 keer bekeken
Good Evening,
Even though I installed the connector box, I see only green lights for Ethernet and Power. I don't see the green light for fiber.
You can find these photos related to the problem attached to this message. I would really appreciate it if you could help me right now.
Best Regards,
Burak Bayrak
Beste antwoord door Anonymous
Hello @BurakBayrak
Has your internet subscription started yet and did you receive a message by e-mail or SMS that the internet line should be active?
If you haven't received that message yet you’ll have to wait for that.
If you have received it and the line should be active then powercycle the fiberbox and the router.
If that doesn't help call KPN customer service 0800-0402 (mo to fr 08.00 - 18.00, sa 08.00 - 17.00).
Ignore the dutch menu and say to the computer you want to speak to an employee, it should then connect you to one.
2 reacties
  • October 4, 2024
Hello @BurakBayrak
  • October 8, 2024
Hi @BurakBayrak, welcome! GeSp is right. The light won't turn green until your signal has been activated on our side. When that happens, you will be notified. And that is the moment you can install.
If you have received that notification, and the light will not turn green, call us!
