Fix on issue
  • apr 30, 2021 8:45 a.m. UTC
  • 45 keer bekeken
 Did you have a fix on this issue? Facing same issue but no response from anyone and couldnt find this topic troubleshooting in google.
Admin: moved to own topic
@Melisa36 Your topic has been moved by admin, so what is the issue ?
  • apr 30, 2021 8:55 a.m. UTC
Now that your message is moved to a separate topic it is unfortunately totally unclear what the issue is. (Thanks moderator)
Can you describe the issue you experience?
Nico_
Topper
  • apr 30, 2021 10:54 a.m. UTC
It was unclear to me as well what the issue is. That's why i moved it to a separate topic
  • apr 30, 2021 10:59 a.m. UTC
@Nico_, It would be a good thing always to mention de topic where the message was originally posted.
So not: Admin: moved to own topic
but: Admin: moved from this topic to own topic
Nico_
Topper
  • apr 30, 2021 11:08 a.m. UTC
@Melisa36
If you could fill in your forumprofile and describe what the problem is i will check to see what i can do for you
