Glasvezel installeren lukt niet, glas-lampje blijft uit en geen internet
  • December 17, 2025
  • 1 reactie
  • 78 keer bekeken
Today I tried to install my Internet. I installed the fibre converter as instructed and plugged in the ethernet port and power cable and the ethernet and power cable light turn green. The "glas" cable stays dark and the installation procedure fails. I tried this again 3 times with no luck and no Internet. How do I solve this!!
Hi ​@Et2. Thank you for your explanation. It looks like the fiber connection is not getting a signal yet, so the installation cannot be finished.
You can try turning off the fiberbox for 2 minutes. If the light on the fiber cable is still off, I suggest you contact our customer service. They can check the connection from a distance and, if needed, send a technician to connect the fiber.
1 reactie
Vikash van KPN
Â
