Help with connection, adapter for 4-pin connection
  • March 8, 2021
  • 16 reacties
  • 828 keer bekeken
Hello,
I moved from Amsterdam Zuidoost to Amsterdam North and have moved my KPN connection to the new address.
I have the the Experia V10 modem that has a DSL connector.
The house has a coaxial connection from ziggo and a 4 pin connector supposedly for KPN.
Would I need a special connector/cable to start using the internet?
Regards,
Vikrant
Thanks! I ordered them for you. They'll get delivered either tomorrow or the day after! Keep an eye on the letterbox!
16 reacties
Thomas van KPN
Hi @Vikrant, welcome to our forum!
There's indeed an adapter for this IS/RA connection. (the four pin connector)
We can order one for you. Could you update your profile and let me know?
  • March 8, 2021
Hi @Thomas ,
I have updated my profile. Can you please order one for me.
Best,
Vikrant
Thomas van KPN
  • March 8, 2021
Thanks @Thomas !!
  • August 25, 2021
@Thomas Hey, I have the exact same issue! Please, I need the four pin connector adapter. Can  you order one for me?
Mvg, Nguyen
Thomas van KPN
Hi @tylerootd, no problem! I ordered one for you as well. Should be in the mail tomorrow!
  • August 27, 2021
@Thomas What a god. That was so fast. Thankyou very much!!!
  • August 27, 2021
@Thomas This is what I got delivered today. I am a bit confused the right cable ( ethernet cable doesn’t fit in any of the holes?)  So how do I get the 4pin connector to → ethernet → to my pc ?
Thomas van KPN
Hi @tylerootd, you put the white connector in the 4 pin adapter and connect it to the DSL port on your (experiabox)modem!
You can then connect your PC to the modem with the UTP cable.
  • August 30, 2021
Hi @Thomas So I took the experiabox out of the meterkast and connected it to the DSL port in the living room. but it still won’t work no matter what. I tried everything! My final request is to let a monteur come by and fix the problem for me.
Thomas van KPN
@tylerootd I'm not sure why I had'nt checked it before but I see you have a Fiber connection so you won't need any of these cables or adapters.
Your modem should be connected to the Fiber unit (in the meterkast?) with a UTP cable in the WAN port.
The 4-pin connection is no longer used in this case.
On this page you can find a bit of background information on our connection types.
Now ofcourse that leaves the question. Is your connection working when you connect everything to the fiber unit?
  • August 30, 2021
Hi @Thomas Yes the connection works when i have it plugged in at the meterkast. But the last monteur told me I could also plug it in at the 4pin port in my living room. I want to have my pc in the living room wired directly there instead of going with a long cable to the meterkast. The last monteur said it was possible but maybe he was mistaken?
Thomas van KPN
I'm afraid not, you could replace the cable in the wall and sockets if you're handy but you can't use the current cable and socket for the connection between your modem and PC
  • October 11, 2021
Hoi @Thomas, ik heb deze adapter nodig ivm verhuizing! Volgens mij hebben we ook een kabel nodig voor de aansluiting met adapter. Groeten, Jennifer.
  • August 13, 2022
Hello,
Regards,
Vikrant
Can somebody please help me. I also need an adapter for this.
  • August 13, 2022
Hello @dunski
Telefoon Stekker NL - RJ11 - Telefoon stekker, Uitgang: PTT male, Ingang:  RJ11 female, Kleur: ivoor
This is what you need
