Hole drilled while getting the fiber optic cable inside and didn't close it, now there's water in my meter cupboard
  • jan 24, 2025 9:36 a.m. UTC
  • 78 keer bekeken
KPN folks drilled a hole while getting the fiber optic cable inside my house and didn't close them and also damaged the plumbing. I have moisture inside my meter cupboard now because of this. I am trying to check if they can fix it. Anyone else had this issue?
I already mentioned this to them when they were taking the order for my connection and the person said he has put that in the notes and somebody will contact you. Never happened, and now in this season the moisture seeped through from the wall.
At the website of KPNNetwerk there is a form you can film in specifically if you have damage because of the installation of fiber.
You can go to https://netwerk.kpn.com/schadeformulier/#schade
2 reacties
  • jan 24, 2025 10:06 a.m. UTC
  • jan 24, 2025 3:54 p.m. UTC
Thanks, I have filed the report. I hope KPN will fix the issue.
