How can i install a wifi disconnect after a particular time?
  • February 23, 2023
  • 1 reactie
  • 13 keer bekeken
Hi, how can I set times for my childrens devices for WiFi
Hi @Ria13M and welcome to our forum!
That depends on what router you have and if you’re using any WiFi boosters or not. Could you tell me which router you’re using? If you’re not sure, you can also post a picture of your router.
In the meantime, this topic has some tips for this as well. Perhaps there are some tips in there you could use as well! If you'd like to read the topic in English, I’ve put it through Google Translate for you so here it is in English
1 reactie
Sanne van KPN
  • February 25, 2023
