Installation issue with Box 12
  • mrt 14, 2024 4:06 p.m. UTC
  • 10 reacties
  • 160 keer bekeken
A BIG MISTAKE IN MY LIFE THAT I CHOOSED KPN INTERNET :( NOT ABLE TO REACH CUSTOMER SERVICE CENTRE REGARDING INSTALLATION ISSUE.
IN THE HELP SECTION GIVING SOME ***
Admin: bericht aangepast op basis van onze huisregels
Unfortunately, I'm going to have to ask you to call us again. When you call us on our 0800-0402 number (which is free), indicate you want to make a ‘monteursafspraak’ and just stay on the line. You should end up with a colleague.
10 reacties
  • mrt 14, 2024 4:08 p.m. UTC
Please check your CAPS-LOCK-button on your type-writer @MAYUR
You can contact KPN by phone (toll-free) 0800 0402, via Facebook or X
  • mrt 14, 2024 4:10 p.m. UTC
i already called and pressed all required numbers but no response and after sometime call got disconnected
  • mrt 14, 2024 4:15 p.m. UTC
When you call within 15 minutes after your last call, the systems knows that you want to speak to a person and you get a person @MAYUR
  • mrt 14, 2024 4:17 p.m. UTC
i tried 4 times within 15mins
i just simply need an appointment with installation thats it
  • mrt 14, 2024 4:27 p.m. UTC
thanks, let me try this
  • mrt 17, 2024 11:21 a.m. UTC
Hi @MAYUR, welcome! Have you managed to reach a colleague and has an installation appointment been made?
  • mrt 17, 2024 11:45 a.m. UTC
@Erik van KPN Unfortunately, I've tried several times online with my KPN ID, but it seems the webpage is not available. I also called customer care and pressed all the required numbers, but nothing happened. Now, since two days , I've been without internet at home, and I don’t know when I will have internet again. The issue is that at home, I had Ziggo internet, which uses a coax cable connection, so I'm not able to connect to the KPN network. I checked at home and found an optic fiber point, but it needs a connection point to be made there. That's why I need a technician from KPN who could finish this installation. Moreover, I was thinking of using a coax converter, but I am not sure if  KPN Box 12 is MoCA enabled, so I don’t think even using a converter will work.
  • mrt 19, 2024 10:02 a.m. UTC
