Installation issue with Box 12
  • March 14, 2024
  • 10 reacties
  • 143 keer bekeken
A BIG MISTAKE IN MY LIFE THAT I CHOOSED KPN INTERNET :( NOT ABLE TO REACH CUSTOMER SERVICE CENTRE REGARDING INSTALLATION ISSUE.
IN THE HELP SECTION GIVING SOME ***
Admin: bericht aangepast op basis van onze huisregels
Unfortunately, I'm going to have to ask you to call us again. When you call us on our 0800-0402 number (which is free), indicate you want to make a ‘monteursafspraak’ and just stay on the line. You should end up with a colleague.
10 reacties
  • March 14, 2024
Please check your CAPS-LOCK-button on your type-writer @MAYUR
You can contact KPN by phone (toll-free) 0800 0402, via Facebook or X
  • March 14, 2024
i already called and pressed all required numbers but no response and after sometime call got disconnected
  • March 14, 2024
When you call within 15 minutes after your last call, the systems knows that you want to speak to a person and you get a person @MAYUR
  • March 14, 2024
i tried 4 times within 15mins
  • March 14, 2024
i just simply need an appointment with installation thats it
  • March 14, 2024
  • March 14, 2024
thanks, let me try this
  • March 17, 2024
Hi @MAYUR, welcome! Have you managed to reach a colleague and has an installation appointment been made?
  • March 17, 2024
@Erik van KPN Unfortunately, I've tried several times online with my KPN ID, but it seems the webpage is not available. I also called customer care and pressed all the required numbers, but nothing happened. Now, since two days , I've been without internet at home, and I don’t know when I will have internet again. The issue is that at home, I had Ziggo internet, which uses a coax cable connection, so I'm not able to connect to the KPN network. I checked at home and found an optic fiber point, but it needs a connection point to be made there. That's why I need a technician from KPN who could finish this installation. Moreover, I was thinking of using a coax converter, but I am not sure if  KPN Box 12 is MoCA enabled, so I don’t think even using a converter will work.
  • March 19, 2024
