Intermittent Packet Loss and High Latency
  • June 14, 2025
  • 212 keer bekeken
Dear KPN Support,
I'm experiencing recurring ping spikes and packet loss. Everything was stable during the 14-day trial period, but the connection has become unreliable since then. I am using ethernet cable directly. Also other devices which are using wifi is experiencing the same issues.
I've attached a screenshot from PingPlotter showing:
  • Packet loss starting at hop 3 ( 139.156.127.10)
  • Latency spikes up to 120ms
  • Consistent jitter affecting real-time usage
Could you please look into this? I'd appreciate it if you could check my routing path and run a line test to rule out provisioning or network issues.
Thank you,
Welcome to the community ​@robfr21, even though it's for a sad reason 😕
Since you already filled your address in your profile, I did a check on your line and I can't find anything that explains your problems.  All I can see, is the restarts you gave the modem, other than that the line seems perfectly stable.
What does your setup at home look like? Is it only the V12 modem or are you using switches, additional routers, wifi repeaters etc?
  • June 14, 2025
I have also restarted my modem through  https://www.kpn.com/service/internet/traag-internet  several times in the past week and it keeps coming back. I am using ethernet cable directly.
Maja van KPN
Maja van KPN
I haven’t heard from you again, so I’m assuming don’t need any more assistance.
If I'm mistaken, I would suggest you contact us another way, so one of my colleagues can measure and test things when they're in live contact with you. For this, you can contact us via Facebook and X, but it's also possible to schedule a phone call, where we will call u back at the time of your preference.  You can request the phone call via our digitale assistent (scroll to the bottom of the page).
  • August 17, 2025
Updating the thread in case others find this thread useful.
I have tried different ethernet cables, received a different router from KPN and I am still getting the same problem. At random times during the day, my internet would just stop working. Trying to access a website would sometime load for 30 seconds and I would need to hard refresh. I guess it is just not possbible to have a highly available internet with KPN. I never had this problem with my previous ISP in the same address. I guess I just got lucky during the first 14 days of usage and did not have this problem.
FYI, I am using ethernet cable directly from the router.
Maja van KPN
I'm sorry to hear you're still facing problems with your connection ​@robfr21 😕
Since you've replaced the router, I assume you have spoken with our customer service? I would suggest you contact us again, and tell us that the new router did not make a difference. My colleagues should be able to open a ‘ticket’ for our tech support, so they can do a deep dive in to your connection!
  • January 28, 2026
@robfr21, did you manage to find the solution?
Â
