Internet light keeps blinking on first day, no internet
  • October 25, 2024
  • 57 keer bekeken
Hello!
This is the first day where my internet is supposed to start working. I received a text message saying that the internet should work and that I should connect the router but the Internet light keeps blinking even after resetting the router. The internet does not work. Could you please help?
Kind regards,
Sopheak
Jan van KPN
  • October 28, 2024
Hello @Sopheak, thanks for your message and welcome to the KPN Community!
If you received a text message that everything should work, the connection is ready to use. The fastest way to get this problem solved, is calling our customer service on the (free) number 0800 0402.
  • October 28, 2024
Hi @Jan van KPN , is it possible to have a technician over to check the installation? It has been 4 days already. I don’t have fiber so the only cable I have is the grey DSL cable which is already plugged in using the Telefoonstekker. Additionally, I also don’t have a customer number. Why? I can’t find it in any of the emails. And I don’t have any invoice yet.
Jan van KPN
  • October 30, 2024
Hi @Sopheak, to see if it's possible to send a technician/mechanic you should call us on the (free) number 0800 0402!Â
