Is it possible to change my IP address?
  • November 17, 2025
  • 126 keer bekeken
Hello
Is it possible to have an IP address changed? That’s a request I get from a Canalsat technician to be able to access streaming channels again
Hello ​@Lart01, i understand that you cannot use a French streaming platform with your KPN connection. KPN does not block services like Canalsat
The only way to change your IP actively, is to cancel your complete registration. But that does not strike to me as a great solution for your problem.
AriënC
  • November 17, 2025
It is not possible to change your IP-adress. Which reason do you have to change it?
  • November 17, 2025
Thanks for your reaction. A technician in France told me I should request this to be able to receive these channels again ( streaming channels from France) after having tried many things already like re-installing the streaming app, telling them I have no proxy or VPN etc...Will speak with a VPN technician tomorrow- Not sure what will happen
AriënC
  • November 17, 2025
Even if it had been possible, I think there's a good chance it wouldn't have helped anything.
Why would one IP address not work and another would?
  • November 17, 2025
Thanks again. Will confirm with KPN technician tomorrow and call the French service provider after that. I feel the IP is the problem as I can connect to these channels via KPN network ( not wifi) and out of home like from my office in Delft :-) or in Schiphol yesterday...Strangely, I had this as a reliable connection for the past 10 years without a glitch and it all went to hell after a power failure at home. Never worked again.
AriënC
  • November 17, 2025
KPN isn't blocking traffic per IP.
  • November 19, 2025
