Need a PTT adapter
  • February 12, 2025
  • 200 keer bekeken
Hello,
The apartment that I just rented doesn't have any other means to connect my router other then an old PTT line.
Please provide me with an adapter since I need it in order to connect, the package did not contain one.
You could go to the nearest KPN store or a builders market like gamma or karwei and get an telephone adapter. That would be the fastest option. You can also call KPN at 0800-0402 and they will send you one but that will take some time.
  • February 13, 2025
  • February 13, 2025
Thank you for your reply and suggestions, I went ahead and bought the adapter from Karwei and everything works now!
  • February 13, 2025
That is good te hear. I hope you will have a great and stable time with KPN 😀
  • February 13, 2025
Well the speed unfortunately is not as advertised, but there is recently glasvezel installed in my area. Maybe this is the solution since the landline is really old.
Bastiaan Sahetapy
Some extra information, we will also replace this connectorbox for the latest one if you call customer service via 0800-0402!
