New connection is not working, GLAS light is off on the FTU
  • January 27, 2023
  • 379 keer bekeken
Helo KPN,
I have a KPN fiberglass connection which has not strted working. Even though i received an sms saying its connected. All the lights in the Fiber optic NT is working except the Glass. All lights on the modem are working well. The internet on keeps blinking but not steady. Is there another solution for this problem?
See the photo
And this one too
Admin: afgeplitst
Beste antwoord door Djorge
Everything is working well. Good job to KPN. I did a reboot powered off connection point and modem. Waited for 20 seconds and all came back to life. My TV arrived and it's working.  Good speed and good service from KPN. As at now everything is solved. Happy Client
NHendriks
Forum|alt.badge.img+12
  • January 27, 2023
Could be that there has been a human error when patching the connection, could also be something else. Fastest way is to call customer support at 0800-0402. This probably needs fixing by a mechanic who can check out the infrastructure.
Thomas van KPN
Hi @Djorge, welcome to our forum! Did you speak to my colleagues in the meantime? From your pictures and what you're telling me it sounds like some action is required from our end. My colleagues at the regular customer service as Nhendriks mentions will be the quickest route
  • January 30, 2023
I went to KPN, office, and they did realize that my address missed an 0, I  had 76 1 instead of 7601. However when I came back, I found all the lights including the Glass on stable green. But it says Connected without internet.
DLD
  • January 30, 2023
Try resetting your modem.
Thomas van KPN
@Djorge a reboot or reset might help as DLD mentions, did that solve your issue?
With the incorrect adress it might mean some action is required to either order a new subscription or change the adress. Did the shop help you with that?
It might also be possible your connection won't work until that process is finished.
  • February 1, 2023
