No internet Connection after installation
  • jul. 6, 2023 7:59 a.m. UTC
  • 104 keer bekeken
After three weeks of rigorous follow-ups, I got the fiber optic connection, and I called a technician to fix the NT box that I did not receive. My billing also started the da. He installed it after 2 days and said that the device could not be connected to the internet since it is a national outage and should be fixed in a couple of hours. It has been 3 days since, and I have called KPN twice every day. They say that they have no idea when it will be fixed.
How can you not have an idea, and how is this acceptable? I need a solution and somebody to fix this immediately.
Could you help with this? I have reached out to customer care two times everyday and nobody has helped.
Regards
Ankit
jul. 10, 2023 11:55 a.m. UTC
Yes, it was corrected last Friday and was finally fixed.
  • jul. 10, 2023 11:51 a.m. UTC
That's sounds like a rough start of your subscription Ankit and that's unfortunate. Did you manage te correct the situation yet? Please let me know if you need any further assistance!
  • jul. 10, 2023 11:55 a.m. UTC
  • jul. 10, 2023 2:15 p.m. UTC
That's great Ankit, I'm glad you resolved the issue!
