No internet Connection after installation
  • July 6, 2023
  • 95 keer bekeken
After three weeks of rigorous follow-ups, I got the fiber optic connection, and I called a technician to fix the NT box that I did not receive. My billing also started the da. He installed it after 2 days and said that the device could not be connected to the internet since it is a national outage and should be fixed in a couple of hours. It has been 3 days since, and I have called KPN twice every day. They say that they have no idea when it will be fixed.
How can you not have an idea, and how is this acceptable? I need a solution and somebody to fix this immediately.
Could you help with this? I have reached out to customer care two times everyday and nobody has helped.
Regards
Ankit
July 10, 2023
Yes, it was corrected last Friday and was finally fixed.
That's sounds like a rough start of your subscription Ankit and that's unfortunate. Did you manage te correct the situation yet? Please let me know if you need any further assistance!
  • July 10, 2023
That's great Ankit, I'm glad you resolved the issue!
