Website geblokkeerd op eigen IP, op andere IP's werkt het wel
  • January 5, 2022
  • 251 keer bekeken
Hi all,
I have a big issue with one website which since yesterday is blocked by my Experia BOX.
Mentioned domain call enlinado.pl  - this is online English school,
And all subpages also e.g. kursy.enlinado.pl
For around one hour I was exploring this site and later it has been completely blocked by my router.
I was trying to renew connection on 2 different PC, mobile phone and even I connect laptop by cable to the router without any result.
Funny thing is that on every other wi-fi or even on 4G connection on my mobile everything is working perfect.
I of course contact with KPN service but they can not see any issue on my connection. And on his notebook website was working well :(
Service guy advice me to check this domain on internet.nl with result below.
I already restored default settings on my router but it doesn’t help
HELP ME PLEASE 🍺🍺🍺
Beste antwoord door Hadex
Ok thank you all, issue is solved… my activity was not properly recognize and their firewall block my IP address at all. After contact with admin enlinado everything is working well again. 🍺🍺🍺
7 reacties
LaurensZalm
  • January 5, 2022
The error states just that the site doesnt fully support IPv6, What does your Browser state when trying to visit the site, cause for me it works fine on my KPN connection.
Also you Could try a Pingplot to the website or possible a Tracert.
just open CMD in windows and run "tracert enlinado.pl" command
  • January 5, 2022
But problem is that for me it was also working fine for half hour or something like that. That’s why I’m sure it is something related to my KPN router. I’m at work now and everything is working perfect. On mobile data also. Below you can see tracert but it is from my work connection so I’ll repeat it when I’ll be at home and I,ll share it to you. Thanks for response.
  • January 5, 2022
Ok here is from my experia at home:
  • January 5, 2022
Hello @Hadex with my KPN Box 12 modem I can reach the mentioned websites www.enlido.pl and www.kursy.enlynado.pl with no problems and I use IPv4 and IPv6.
CC: @LaurensZalm
LaurensZalm
  • January 5, 2022
Well thats rather interesting considering mine looks exactly the same just diffrentiating the first 2 IP's all the other responses are exactly the same and for me it works perfectly, if your router would indeed not pass it through the routing would be completely suspended after the "router”aka the first IP.
So this means it does pass through the router in working order ​, could you show a Printscreen of what happens if you try to open the webpage ? ​​​​​​
  • January 5, 2022
LaurensZalm
  • January 5, 2022
Ah they blocked your IP i see…
Well you got it working so that was the goal :muscle::thumbsup:
