Wifi name and password change - KPN Box 12
  • April 12, 2021
  • 1206 keer bekeken
Hello,
How do I change the name of my network and the password?
Changing through KPN's terrible website doesn't work (says it's malfunctioning) and changing through the Modem website only lets me change the Admin Password.
Can anyone help considering the modem BOX 12?
Thanks!
​​​​​​​Lucas​​​​​​​
Hi @Lucas Veiga, welcome to our forum!
Did you try it through this page on our site? You should be able to change your SSID and WPA key there!
Otherwise you can also do it manually there's a detailed explanation in this topic:
Thomas van KPN
  • April 13, 2021
Thomas van KPN
I havent heard from you in a bit so I'm assuming you succeeded! If you havent or you have any additional questions you know where to find us!
  • April 15, 2021
Hi Thomas,
Thanks! I didn't change it yet but looks like it's going to work with the 2nd solution.
However, please note that the first solution (page on the website with the link) you have shared isn't working (and also for other costumers on the Forum who complained about that).
Best regards,
Lucas
Thomas van KPN
Ah thanks for the reply Lucas, I'm passing your feedback to my colleagues!
