Hi @Lucas Veiga, welcome to our forum!
Did you try it through this page on our site? You should be able to change your SSID and WPA key there!
Otherwise you can also do it manually there's a detailed explanation in this topic:
I havent heard from you in a bit so I'm assuming you succeeded! If you havent or you have any additional questions you know where to find us!
Hi Thomas,
Thanks! I didn't change it yet but looks like it's going to work with the 2nd solution.
However, please note that the first solution (page on the website with the link) you have shared isn't working (and also for other costumers on the Forum who complained about that).
Best regards,
Lucas
Ah thanks for the reply Lucas, I'm passing your feedback to my colleagues!
