Doesn't add product in MyKPN
  • mei 18, 2021 12:35 p.m. UTC
  • 131 keer bekeken
I have an internet subscription but when I try to add it to my products on the step 'provide your 3 digits from your bank account' it fails. It says that does not exist. I had the subscription from Telfort before. What should I do in this situation?
Beste antwoord door Lisa
Thank you! I do not see an issue. Can you please try to add the product to MyKPN by selecting ‘NO’ when the form asks you ‘if you are home and connected to your KPN internetconnection?’.
I'll send your customer number in a private message. This should allow you to add you product.
Lisa
Forum|alt.badge.img+17
  • Oud moderator
  • mei 19, 2021 1:32 p.m. UTC
Welcome @Roman_! I'm sorry to hear that you're facing difficulties adding your subscription to MyKPN. Did you enter the 3 last digits of your bank account? You're supposed to receive this ‘does not exist’ notification when you enter the wrong digits.
Let me check if I see any problems. Can you enter your subscription details in your profile and notify me when that has happened by writing a reply? I need your postal code, house number, customer number, and last 3 digits of your bank account. Please enter the last three digits of your bank account in ‘Persoonlijke Opmerkingen’.
You can also send me a private message if filling in your profile causes problems.
  • mei 19, 2021 2:05 p.m. UTC
Hi Lisa, I’ve filed the form, but I can not find my customer number. I left in the note which one I used to use in Telfort.
Lisa
  • Oud moderator
  • mei 19, 2021 2:59 p.m. UTC
  • mei 19, 2021 3:09 p.m. UTC
ok wait for your message, thanks
Lisa
  • Oud moderator
  • mei 22, 2021 7:10 a.m. UTC
Problem solved! ;)
