Mikrotik hEX S configuration on glasvezel
  • November 2, 2020
  • 1092 keer bekeken
Greetings,
apologies I cannot write Dutch. I use translator to read messages.
I am recently begin moved from Telfort to KPN.
I have glass fiber connection and I used to have Mikrotik for internet and bridged IPTV.
Since the move, KPN uses routed IPTV.
I have red a lot of articles also in netwrkje site…
Still unable to get the both working.
I think (but not sure) that the bigger issue is that the configuration I found refers to a pppoe and needs credentials to add to the connection.
That I dont have. I dont use a DSL connection.
this link in KPN Forum, shows a configuration (similar to the one I saw in Netwerkje).
https://forum.kpn.com/thuisnetwerk-72/configuratie-mikrotik-rb4011-494258
but again, it refers to pppoe: ā€œadd add-default-route=yes allow=pap disabled=no interface=vlan1.6 \
    keepalive-timeout=20 max-mru=1500 max-mtu=1500 name=pppoe-client user=\
************@direct-adsl
ā€
Can someone help me to find a configuration that works using fiber optic?
As we speak, I do have internet and a basic TV as I use the Telfort configuration with a bridged IPTV… but the configuration is incorrect; internet vlan is wrong (even if it works) and IPTV is very limited.
No credential for internet ar used at the moment, only DHCP clinet.
I hope someone can help me out.
Kind regards
Beste antwoord door wjb
Can you share the whole configurationfile of your Mikrotik?
Although I am not familiar with the configuration of a Mikrotik, I at least can have a look at it to see if I can detect possible causes.
DidĀ you move from Telfort to KPN yourself by changing your subscription or is this due to the automatic integration of Telfort toĀ KPN.
7 reacties
  • November 2, 2020
I would like to add that I am not interested in the phone part.
Only Interent and IPTV
Thanks
Lisa
Forum|alt.badge.img+17
  • Oud moderator
  • November 8, 2020
Welcome here,Ā @Universo! Thank you for your topic.Ā Lately,Ā It's been very busy on our Forum:eyes:. Sorry for my late reply. I am not right person (here),Ā to help u with this, because I lack knowledge about this subject:speak_no_evil:. But I hopeĀ @Nick83Ā might be able to give you a tip or knows whatĀ needs to be changed allowing you to use IPTV!Ā :nerd: Ā
  • November 8, 2020
Engels…
@wjbĀ ??? šŸ˜‰
  • November 8, 2020
Lisa
  • Oud moderator
  • November 14, 2020
Let us know if you still need our input!Ā :sunglasses:
  • November 19, 2020
Thanks for your answer.
I was moved from Telfort to KPN. Not a choice.
I figure out that I am only administratively moved and not technically.
The needed info for mikrotik configuration that are present in a normal KPN modem, are not present in the telfort modem I have and therefore cant really move on.
Due to the missing phone support to solve this issue and since this is creating a big issue for TV and my family.. I made a decision to move to a different provider.
I will be challenged with same problems. But eventually I will solve them. Will also have a 1GB connection for a bit less to spend..
For KPN
In case KPN read this; I would have not moved.
But its too hard to get help and the move from telfort to kpn is too slow for what I need.
On top of it, I was called by someone from KPN to ask why I was moving, I liked the idea and openness at first but soon I felt harassed.. quite some aggressive way to ask questions and questioning my choice.
Difficult to change my mind with that behave.
If he wanted to make me a better offer, he had to simply do that and match what I got offered by the other ISP. And be nice.
It did not happen.
I suggest to educate the call center agents in their soft skill a bit better.
regards
Ā
B.G
Nieuwkomer
  • December 7, 2020
add comment="vlan4_IPTV connectie met ether1" interface=ether1-Wan name=vlan4 \
Ā Ā Ā  vlan-id=4
add comment="vlan34_Internet connectie met ether1" interface=ether1-Wan name=\
Ā Ā Ā  vlan34 vlan-id=34
