Resetting the pincode for my tv account does not work in the MijnKPN app
  • November 11, 2025
  • 89 keer bekeken
Hello, I forgot the parental control so i push the button forgot scan the QR code open the link, inloggen in mijnkpn, it s schearching to arrive to this message
Something is wrong
It looks like the Reset PIN Code tool is not working at the moment.
this is the same for the last 2 months so I call the klanten service during one hour somene try something and didnt succeed until they hang up.
I try the factory reset: same thing the pincode is not working.
Hello ​@yoannfilip, if you can't reset the TV pincode by yourself, the best way to get a new pincode is by contacting our customer service. You can make a call me back appointment and then a KPN agent will call you back on a moment that suits you.
The agent can then reset your pincode and can register a ticket for the servicetool, because this toll should work for you. If calling is a step to far for you because of a possible language barrier? You can also contact KPN by using X or Bluesky or  Facebook messenger and as option Instagram
  • November 11, 2025
Hi ​@yoannfilip ,
I think it's the TV receiver's PIN code, is that correct?
A moderator can check if they can reset the PIN code. Could you please fill out your forum profile? It may take a few days for the moderator to respond.
  • November 13, 2025
Hello Jeroen.
I did this and the answer was: "sorry it s not possible to give you or send you another pincode. Have a good day".
So at this end I know the service!
I even did a reset factory myself without success.
A pity.
The answer you received surprises me.
Luckily it is possible to reset a pincode. You will receive a couple of e-mails with your account number and one with a new KPN TV pincode.
  • November 14, 2025
Hello. You are a star. I received my pincode and it s working. Thank you Jeroen
