KPN Hussel koppelen werkt niet - Mbs delen lukt niet
  • April 27, 2022
  • 128 keer bekeken
Beste klantenservice,
Wij hebben een probleem met het aanmelden voor KPN hussel.
Het is gelukt om één telefoon nummer toe te voegen, maar bij het tweede telefoon nummer krijg ik keer op keer een foutmelding.
 Wij hopen dat jullie ons hiermee kunnen helpen.
Met vriendelijke groet,
N.B Address are the same
@vit I checked the situation, and for the number ending om 491 the house number addition is missing.
Because I need to do a verification I can't do this for you.
I would advice you to call my colleagues on 0800-0402, when the house number is changed everything else should work!
7 reacties
  • April 30, 2022
I have added all numbers at
https://www.kpn.com/hussel/aanmelden.htm
5 month ago
One was added successfully and one not
Addresses are correct
Rutger van KPN
@vit Welcome to our forum.
I tried to add the other number to the household too, can you check if you can share data now?
  • April 30, 2022
Thank you very much @Rutger_  but I still see only 2
here: https://mijn.kpn.com/classic/#/tv-internet-bellen/mkmv
*Admin* Post editted because of privacy.
Rutger van KPN
@vit That is weird, because I see the same KPN ID for the 3 numbers.
Have you tried adding the number again in MijnKPN and if you did, what screen did you get trying it?
  • May 1, 2022
Thanks for helping @Rutger_
The result is next:
Rutger van KPN
  • May 3, 2022
@Rutger_ Thank you for help. It works
