Accidental maritime roaming charge (€60.50) on invoice
  • nov 10, 2026 10:21 a.m. UTC
  • 54 keer bekeken
Dear KPN Support Team,
I am writing regarding an unexpected roaming charge of €60.50 on my latest invoice.
On October 10th at 18:53, an unintentional data transfer of only 6.2 MB was registered under the maritime satellite network (SAT), which immediately triggered the €60.50 roaming safety cap.
During that time, I was traveling in Europe on a cruise departing from Spain. While at port in Spain (ESP) and upon arriving in France (FRA) the next morning, my phone connected normally to EU terrestrial networks. However, shortly after leaving port, the device automatically connected to the ship's maritime satellite network in the background without my realization.
As a SuperUnlimited plan customer, I was unaware that the connection had switched to maritime satellite. Given that this was a brief background transfer (approx. 6 MB) and the first time this has occurred, I would be grateful if KPN could consider a one-off goodwill credit (coulance) to waive or credit this fee.
My customer details and mobile number have been filled in my forum profile for verification. Thank you for your assistance.
Kind regards,
George Lin
Hi ​@georgelin . Welcome to the KPN Community.
Thank you for your message and for explaining the situation so clearly.
I’m sorry to hear this happened. Ship networks run over satellite, so they fall outside the regular EU roaming rules. That’s why even a small amount of background data can get expensive quickly, and it’s a real shame this happened on your cruise. The €60.50 cap did its job, though: it blocked any further data use, so the costs couldn’t keep going up.
To stop this happening on future trips, you can send a text message with BESCHERMING AAN to 1266. This lowers your protection limit from €60.50 to €0. Your phone then can’t use any data outside your bundle when you’re outside the EU or connected to a satellite or maritime network, such as on a ship or a plane. You can’t run up unexpected costs this way, even when your phone connects in the background without you noticing. Data within the EU stays available as usual.
Thanks again for reaching out, and I hope you still had a wonderful cruise!
  • nov 12, 2026 10:46 a.m. UTC
mrGanesha
  • nov 12, 2026 12:14 p.m. UTC
​@Erwin van KPN escaleren jullie als moderators wel eens dat klanten graag standaard BESCHERMING AAN willen hebben ipv dat je dat expliciet moet SMS’en?
En wat is dan de reactie die vanuit corporate terugkomt?
  • nov 12, 2026 12:40 p.m. UTC
Ik denk dat corporate dan zegt dat het inkomsten oplevert.
  • nov 13, 2026 8:14 p.m. UTC
Goede vraag ​@mrGanesha , en een terechte. Het ligt ook voor de hand om dat te vragen na een topic als dit.
Hoe de interne lijntjes precies lopen, kan ik hier niet allemaal toelichten. Wel kan ik zeggen dat signalen en feedback uit de Community niet ongemerkt verdwijnen. Situaties zoals die van ​@georgelin , en ook het idee om de bescherming standaard op €0 te zetten, worden gedeeld met de collega’s die over dit soort instellingen gaan. Of en wanneer dat tot een aanpassing leidt, kan ik niet beloven. Zo’n wijziging raakt namelijk aan meer dan alleen dit ene scenario.
Het blijft een afweging. De standaardlimiet van €60,50 komt voort uit Europese regelgeving. Die schrijft voor dat er standaard een kostenlimiet geldt voor dataverbruik buiten de EU, zodat niemand ongemerkt met een hoge rekening thuiskomt. Tegelijk zijn er ook klanten die buiten de EU, op een boot of in een vliegtuig, juist wél bewust even willen kunnen internetten zonder eerst iets aan te moeten zetten. Zet je de limiet voor iedereen standaard op €0, dan help je de ene groep en loopt de andere groep op een onhandig moment tegen een blokkade aan. Er is dus niet één instelling die voor iedereen goed uitpakt.
Daarom vinden we het belangrijk dat klanten zelf kunnen kiezen. Met BESCHERMING AAN naar 1266 bepaal je zelf hoe streng je het wilt hebben. En hoe vaker we die tip hier delen, hoe meer mensen er vóór hun vakantie van weten.
  • nov 14, 2026 3:00 a.m. UTC
Hi Erwin, thank you for the quick response and the great tip! I have already followed your advice and sent the SMS "BESCHERMING AAN" to 1266 to set my protection limit to €0 so this won't happen again in the future.
However, as a loyal KPN customer with both Internet and Mobile subscriptions, this charge was completely unintentional and happened within just a few minutes of leaving the port in Spain due to automatic background data. Since this is the very first time something like this has occurred on my account, could you please check if it is possible to make a one-time exception (coulance) and credit the €60.50 charge?
I would really appreciate your help with this.
Thanks for your reply, and good to hear you’ve already set BESCHERMING AAN. You’re now fully protected on future trips.
I understand why you’re asking, and I can see this was unintentional. Unfortunately, we can’t make an exception and credit the €60.50 in this case. The data use was registered on a maritime satellite network, which falls outside the EU roaming rules, and the charge was applied correctly. The €60.50 limit is exactly what’s meant to protect customers in this situation: it stopped all further data use right away, so the costs couldn’t go any higher. Because the charge is correct and the protection worked as intended, there’s no basis for a credit, even though this was the first time and you’ve been a KPN customer for a long time with both Internet and Mobile.
I know that’s not the answer you were hoping for, and I’m sorry this cast a shadow over your cruise. The good news is that with your limit now at €0, this can’t happen to you again, even if your phone connects to a ship’s network in the background.
