How to use my KPN postpaid sim in India
  • aug 8, 2025 12:59 p.m. UTC
  • 9 reacties
  • 168 keer bekeken
I bought KPN postpaid sim in NL and im going to India. How to do the calls from India to NL?
9 reacties
  • aug 8, 2025 1:12 p.m. UTC
First. Activate the card while still in the Netherlands!!
And from India you can only use standard “BELTEGOED”.
Using outside EU is not standard for prepaid en expensive.
Tarifs are unfortunetely not specified.
But it's € 2,55 per minute for calling, receiving about € 2,55 p/min. SMS per 160 signs € 2,55.
DATA 4/5G is very expensive: € 2,55 per MB!
A local prepaid card is much more afordable.
  • aug 8, 2025 1:33 p.m. UTC
Two questions here:
  1. My postpaid sim card is activated. is your answer same for Postpaid also?
  2. To call from India to NL, should i do any settings in the mobile?
  • aug 8, 2025 2:19 p.m. UTC
Oh, postpaid. You mean an abonnement (subscription) ???
The bundels for calling/data within the subscription are not valid outside EU.
For a subscription (abonnement) the tarifs are different.
For there are these bundels
100 Min/MB/sms* € 9,99. Send sms with text SUPER VOORDEEL 100 AAN to number 1266.
2000 MB/min/sms* € 29,99 sms SUPER VOORDEEL 2000 AAN to number 1266.
2000 MB data only € 19,99 sms VOORDEEL DATA 200 AAN to number 1266.
Costs without bundel (calling when you only have the data bundel of no bundel)
Data usage € 2,50 per MB
Calling from Netherlands/EU € 0,30 per minuut
Calling in India € 1,- per minuut
Receive calls in India € 0,50 per minuut
Receive SMS gratis
Send SMS € 0,30 per sms*
All sms tarifs are per 160 signs.
Change setting not necessary
Your phone wil automatically take one of these providers
  • aug 8, 2025 4:26 p.m. UTC
is this for Prepaid?
  • aug 8, 2025 4:31 p.m. UTC
Now you're confusing me. KPN has prepaid en subscription. What do you mean by postpaid? The term postpaid is also not known by Google translate.
RBxx
  • aug 8, 2025 4:52 p.m. UTC
​@PeterG  Prepaid == vooraf betalen (pre paid)    Abonnement == achteraf betalen (post paid)
  • aug 8, 2025 5:13 p.m. UTC
Ik heb alle gegevens gegeven. Voor prepaid en abonnement. =Postpaid?
I've given all the info voor prepaid and subscription. Postpaid is a term which confuses.
Ja, dat kan wel zo zijn ​@RBxx .
Maar eerst geeft ik de gegevens voor prepaid (want nogmaals postpaid is volgens mij helemaal geen officiele term. Google translate kent het niet.)
Dat zou niet goed zijn volgens TS.
Dan geef ik gegevens voor abonnement.
En nou vraagt ie weer voor prepaid, DIE IK AL HEB GEGEVEN. Dus ik kap hier.
Net of je achter het stuur zit en een ander navigeert. Nee, hier moet je naar rechts, nee toch links. Eh, rechtdoor. Toch terug? Je kunt met mij alle kanten op maar er zijn grenzen.
RBxx
  • aug 8, 2025 5:21 p.m. UTC
Hi and welcome to our community ​@Shridhar!
I see there was some misunderstanding at first, but later on Peter shared the right information and abroad bundles with you :)
Did you manage to find the best solution for you, with this info? In most cases, it's easier ánd cheaper to choose for one of the bundles. You can also take a look at our abroad bundles over here at our website.
