It is not possible to order extra mobile data through sms
  • dec 17, 2024 6:58 p.m. UTC
  • 105 keer bekeken
I can upgrade my 20GB limit via the app. But, texting NL2000 to 1266 no longer works for the last month or so. It says “Uw ingevoerde code is niet herkend. Probeer het nog een keer.” Why?
Beste antwoord door RBxx
Hi ​@dimitris93
You are trying to add 2GB to the daily amount of 20GB of your unlimited data subscription?
Did you send a text message  NL2000 AAN  to 1266?
RBxx
  • dec 17, 2024 7:57 p.m. UTC
Hi ​@dimitris93
  • dec 17, 2024 8:18 p.m. UTC
Oh god… You are right.
I thought “aan” was just Dutch for the word “to”. Thanks….
RBxx
  • dec 17, 2024 8:26 p.m. UTC
You were right, but in this case “aan” has another meaning: ON  so you’re asking to switch 2GB on.
