KPN Dual Sim not working properly
  • aug 6, 2026 1:15 p.m. UTC
  • 1 reactie
  • 17 keer bekeken
We need to check once again if the duo SIM card with simkaartnummer **************** is working -I have received confirmation that it is active, but can we check also if it is registered in the mobile network? Thank you
one card is with us-at Ansart, the other is at our customer in Germany
Admin: removed the simcard number due to privacy concerns
Hi ​@Ansart, welcome to our community! This community is intended as a forum for customers to help other customers.
I'm not sure I can actually help you with this here, especially because it's concerning a sim-card of a customer.
I can however, tell you that a duo-sim simcard can only have one active card at a time.
There are no clear rules which card takes priority so if you try to connect to the network with both cards at the same time they'll both have a terrible connection.
If this is concerning a business connection or subscription you might want to talk to our KPN Business colleagues over at 0800-0403 or 0031612001200
1 reactie
Thomas van KPN
  • aug 10, 2026 2:31 p.m. UTC
