Roaming not working in UK
  • September 25, 2025
  • 162 keer bekeken
While in London the roaming wasn't working despite having worked previously in many other visits. Nothing was loading but every now and then I received a message from Whatsapp. The worst was that Google maps wasn't loading at all. The network was connecting to 3 UK. Another friend also on KPN was having the same. I restarted the phone, he tried to select other networks manually but nothing worked. Is there an outage or is this normal network behavior we should expect from now on? I still had quite a lot of gb in budble and the bundle is across Europe.
Hi ​@ICameToComplain, welcome to our community.
How incredibly frustrating that you've had such a poor connection. Let's see if we can find a solution for this.
  • Have you tried resetting the network settings? You can do this in the connection settings.
  • Did you experience this issue everywhere or only in a specific location in London?
  • In the UK, you can connect to networks such as Vodafone, Virgin/O2, and Sky. Did none of these work?"
Forum|alt.badge.img+28
  • September 28, 2025
My friend that was experiencing the same was trying different networks but it was not connecting. It was in different places in central London
  • September 30, 2025
Have you also tried resetting the network settings? If you let me know which phone you're using I can tell you exactly how to do this.
Â
