Box 12 does not work anymore after power failure
  • apr 14, 2025 9:55 p.m. UTC
  • 214 keer bekeken
Hello,
unfortunately after a power failure the modem stopped working, it keeps restarting itself which is why the internet doesn't work. I have KPN box 12. what could be the cause of this problem and how to fix it.
Beste antwoord door PeterG
This is a malfunction for which you best call. This can be done 24/7 with a malfunction. The VRS understands English.
The free of charge number is 0800-0402 ( <- tab on mobile to call)
Malfunction 24/7
Other:
monday - friday 08:00 tot 18:00 uur
saturday 08:00 tot 17:00 uur
sundays and holidays closed
Or let kpn call you back.
Have you tried to turn the modem off for 3 minutes en then on? With the white (press) button on the rear.
  • apr 14, 2025 10:50 p.m. UTC
Malfunction 24/7
Other:
RBxx
  • apr 15, 2025 5:30 a.m. UTC
Hi ​@Jarek203 , there are issues with some of the power adapters supplied with the KPN Box 12, causing the modem to go into a restart loop. Contact KPN as ​@PeterG suggests.
Some customers obtained a replacement in a KPN shop.
  • apr 15, 2025 1:11 p.m. UTC
Hello,
thank you for helping me solving this problem. I went to kpn shop and I received new router. Now I have to install it. How to do it?
  • apr 15, 2025 1:19 p.m. UTC
Just connect it. It shall automatically load the software.
