Box 12 does not work anymore after power failure
  • April 14, 2025
  • 213 keer bekeken
Hello,
unfortunately after a power failure the modem stopped working, it keeps restarting itself which is why the internet doesn't work. I have KPN box 12. what could be the cause of this problem and how to fix it.
Beste antwoord door PeterG
This is a malfunction for which you best call. This can be done 24/7 with a malfunction. The VRS understands English.
The free of charge number is 0800-0402 ( <- tab on mobile to call)
Malfunction 24/7
Other:
monday - friday 08:00 tot 18:00 uur
saturday 08:00 tot 17:00 uur
sundays and holidays closed
Or let kpn call you back.
Have you tried to turn the modem off for 3 minutes en then on? With the white (press) button on the rear.
  • April 14, 2025
Malfunction 24/7
Other:
RBxx
  • April 15, 2025
Hi ​@Jarek203 , there are issues with some of the power adapters supplied with the KPN Box 12, causing the modem to go into a restart loop. Contact KPN as ​@PeterG suggests.
Some customers obtained a replacement in a KPN shop.
  • April 15, 2025
Hello,
thank you for helping me solving this problem. I went to kpn shop and I received new router. Now I have to install it. How to do it?
  • April 15, 2025
Just connect it. It shall automatically load the software.
