Can I set modem interface to English?
  • apr. 4, 2024 6:15 p.m. UTC
  • 234 keer bekeken
Is the interface not available in English for mijnmodem.kpn It used to be in English if i remember correctly but does not seem to be the case anymore. Can someone let me know how to change the config portal language to English?
Admin: question split off to its own topic
  • apr. 4, 2024 8:33 p.m. UTC
What brand and type modem do you have from KPN @mayank13 .?
Some models can change into English
Vikash van KPN
Hi @mayank13. Unfortunately, you haven't provided an answer to the question above . If you have an ExperiaBox v10 or v10a, you can find this in the top right corner.
  • mei 7, 2024 5:58 p.m. UTC
Hello to everyone. The same question is related to BOX V14. Is it possible? I couldn’t find anything except the exit button in the top right corner.
Vikash van KPN
On the KPN Box 14, it's not possible to change the language to English, unfortunately.
  • mei 8, 2024 10:58 a.m. UTC
I see. Thank you for your reply.
